pompey1 Posted March 25, 2018 Share Posted March 25, 2018 I have a problem with the camera view. Once I have viewed the area I can't close the tab to return to the plan without closing the whole program down; it seems to be locked up. Any one have any suggestions. Thanks, Sylvia Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 25, 2018 Share Posted March 25, 2018 You either close the camera view tab or if you want to leave it open, on a PC, you use the Windows keyboard command "Ctrl (control key) - Tab key" to switch between open windows in an application.If you have to do anything else, you should communicate to Tech Support for help DJP Link to comment Share on other sites More sharing options...
pompey1 Posted March 25, 2018 Author Share Posted March 25, 2018 Thanks for responding . That's what I'm doing but the view won't close. The only way I can close it is to close down the whole program. I'll talk to tech support tomorrow. Thanks. Link to comment Share on other sites More sharing options...
