pompey1
camera views lock
I have a problem with the camera view.  Once I  have viewed the area I can't close the tab to return to the plan without closing the whole program down; it seems to be locked up. Any one have any suggestions.
Thanks,
Sylvia
You either close the camera view tab or if you want to leave it open, on a PC, you use the Windows keyboard command "Ctrl (control key) - Tab key" to switch between open windows in an application.If you have to do anything else, you should communicate to Tech Support for help
Thanks for responding .  That's what I'm  doing but the view won't close. The only way I can close it is to close down the whole program.  I'll talk to tech support tomorrow.
Thanks.
