Sign in to follow this
DIYAdam
Elevation View still showing foundation
I have 3 Elevation camera views setup outside the terrain but the foundation is still shown in all views. the terrain skirt is set to 120" and the plan is placed inside the terrain premiter.
Thanks for any help
You posted this thread but never responded.
Eric, yes I did and everything worked just like you said it would and I had the foundation not showing or showing depending on how the camera was positioned relation to the terrain skirt but as my learning curve continues I had to make some changes to the plan, elevation then the foundation started showing again.  I even deleted the terrain and rebuilt a new one foundation still shows.
What are you trying to do now -- something different than what you asked about in the other thread?
And posting the plan will be easiest for me.
Your terrain is not displayed in elevation views (layer display options).
Also, since your terrain is flat, you can mask whatever you want with a filled cad box, in plan, or in layout.
Thank you, I knew it was something simple  Is there a way to add custom layers?
