LenB10p Posted March 5, 2018 Share Posted March 5, 2018 I have created a multistory building with a garage attached to it via a covered walkway (porch). I want to delete the garage and connecting walkway but when I do this I can't delete the roofs. How can I do this without changing the roof on the main house? Many thanks LenB Link to comment Share on other sites More sharing options...
solver Posted March 5, 2018 Share Posted March 5, 2018 What happens when you rebuild the roof? Link to comment Share on other sites More sharing options...
LenB10p Posted March 5, 2018 Author Share Posted March 5, 2018 Quote If I delete the garage and the porch at all levels (foundation to the 2nd storey) and rebuild the roof on the main house, it produces a different look. Take a look at the attached. Before deleting the garage and porch.docx Link to comment Share on other sites More sharing options...
solver Posted March 5, 2018 Share Posted March 5, 2018 Please post images directly as you did in your post above. Rebuilding your roof is the only option in Suite. Link to comment Share on other sites More sharing options...
LenB10p Posted March 5, 2018 Author Share Posted March 5, 2018 Apologies but I'm not certain that I understand your answer. Are you asking me to post the images into my comments here? Also, are you saying that I can't change the way that the roof is rebuilt after deleting the attached garage and porch? It that is the case, then I'll have to create this building from scratch without the garage and porch to get the roof on the house that I want. Again, I'm not an architect or builder, but simply want to design a house that I can hand to an architect to create a professional version. Link to comment Share on other sites More sharing options...
solver Posted March 5, 2018 Share Posted March 5, 2018 7 minutes ago, LenB10p said: Are you asking me to post the images into my comments here? Yes please. 8 minutes ago, LenB10p said: Also, are you saying that I can't change the way that the roof is rebuilt after deleting the attached garage and porch? No, I'm saying that in Suite, the only way to get rid of a roof is to rebuild all roofs. 9 minutes ago, LenB10p said: It that is the case, then I'll have to create this building from scratch without the garage and porch to get the roof on the house that I want. Why would you think that? If you redraw the house without the garage and build the roof, you will be where you are now -- after deleting the garage and rebuilding the roof. What's wrong with the roof after rebuilding without the garage? Link to comment Share on other sites More sharing options...
LenB10p Posted March 6, 2018 Author Share Posted March 6, 2018 I can see the problem but don't know how to fix it. The roof build after deleting is higher than the original and the window on the staircase does not have a gable roof over it. I'm designing from my current house (which I have used the plans from the builder)that I want to rebuild in another location. The dollhouse view shows the second floor as it should be (the porch roof encroached due to my poor creation) but this reflects the real floor structure The floor plan for the second floor shows the roof outline even though it was removed before removing the porch and garage. Any help will be appreciated. Thanks Link to comment Share on other sites More sharing options...
solver Posted March 6, 2018 Share Posted March 6, 2018 Post your plan file and I'll have a look. Close Suite before attaching. Link to comment Share on other sites More sharing options...
LenB10p Posted March 6, 2018 Author Share Posted March 6, 2018 Eric hopefully I've attached the correct plan file. Keep in mind that I'm not a builder or architect but want to create a plan that a professional could use as a starting point. And thanks for your help. Len NewBuild_planG.plan Link to comment Share on other sites More sharing options...
solver Posted March 6, 2018 Share Posted March 6, 2018 I forgot to ask if you had an image of the real house you could post. You plan still had the garage, so I deleted it and rebuilt the roof. Does this look correct? Link to comment Share on other sites More sharing options...
LenB10p Posted March 6, 2018 Author Share Posted March 6, 2018 That what I get when I rebuild as well. If you don't delete the garage and create a 3D full perspective, you can see the roof line front and back of the house which is correct. In the view you've created I notice that the window on the stairway at the front does not have a gable wall above it. I don't know the software well enough to understand why. The plan with the garage included does have the correct roof line. Part of my challenge is remembering how I created the half storey/attic which enabled me to have the dormer windows. Does this make any sense? These photos should give you some idea of what the real house looks like. Link to comment Share on other sites More sharing options...
Jo_Ann Posted March 6, 2018 Share Posted March 6, 2018 You set lower ceiling heights for the 2nd floor. Then turned off 'auto build' roof. Then raised ceiling heights. When you rebuild the roof, it builds with the higher ceiling height. You most likely created individual 'rooms' for the 'dorms', with higher ceiling heights. After 'auto build roof' was turned off, you were able to delete the walls to those 'rooms'. You now have to recreate the 'rooms' to rebuild the roof correctly. Link to comment Share on other sites More sharing options...
solver Posted March 6, 2018 Share Posted March 6, 2018 Do I see a Morgan in the drive? Link to comment Share on other sites More sharing options...
LenB10p Posted March 6, 2018 Author Share Posted March 6, 2018 Yes...but it is the garage until spring arrives in the UK Link to comment Share on other sites More sharing options...
solver Posted March 6, 2018 Share Posted March 6, 2018 This should get you started. Turn on Auto Rebuild Roofs. Go to Edit>Reset To Defaults Select All Floors, and Roof Directives In Walls As Jo Ann said, you need to lower the ceiling height on the top floor -- Go to your defaults and make the rough ceiling 1728 mm. This should change the entire top floor. To create the raised roof over the windows, draw in 3 walls behind each one as shown in blue to create a small room. Change (raise) the ceiling height in that room to raise the roof. Link to comment Share on other sites More sharing options...
LenB10p Posted March 6, 2018 Author Share Posted March 6, 2018 Many thanks to both of you. I'll let you know how I get on. Link to comment Share on other sites More sharing options...
Jo_Ann Posted March 6, 2018 Share Posted March 6, 2018 Correction: I think that you took a shortcut and right clicked on the 'dormer' windows, and chose 'gable over window/door', (instead of building dormer 'rooms' with higher ceiling heights). What Eric is suggesting, is the way it should be done. Link to comment Share on other sites More sharing options...
solver Posted March 6, 2018 Share Posted March 6, 2018 I forgot to add, once the roof is correct, turn off Auto Rebuild Roofs, and delete the walls used to raise the roof over the windows. Then change the ceilings to the correct height. Link to comment Share on other sites More sharing options...
LenB10p Posted March 8, 2018 Author Share Posted March 8, 2018 This worked and helped me to recall how to do this...forgot the process over the past 18 months. Now for my next challenge...can I add a garage to this plan? Link to comment Share on other sites More sharing options...
Jo_Ann Posted March 8, 2018 Share Posted March 8, 2018 If you intend to continue modifying the plan, then you need to keep 'auto build' roof turned on. I would build those window 'rooms' using the invisible 'divider wall', and then leave them there, and also leave those 'rooms' set to the finished ceiling height. The rest of floor 2 needs to be left at the lowered ceiling height. Hint: uncheck 'ceiling over this room' in all the remaining 2nd floor rooms, and this will allow you to view the rooms with the camera. The roof can rebuild over and over again (as you modify the plan) and will not change the way the 2nd floor appears. Remember when you begin to build the garage, that you already have a 2nd floor. You just need to manually draw the walls over the 1st floor. Link to comment Share on other sites More sharing options...
LenB10p Posted April 11, 2018 Author Share Posted April 11, 2018 Well, I've followed all your guidance as best possible and seem to have hit another snag. For some reason there is a roof pane inside a ground floor room and I cannot for the life of me figure out what I've done wrong. Also, the upstairs rooms above have something poking up into the attic area. Any thoughts or suggestions? See the attached views. Thanks Len Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 11, 2018 Share Posted April 11, 2018 Post the plan so others can also look and investigate instead of just guess. DJP Link to comment Share on other sites More sharing options...
Jo_Ann Posted April 11, 2018 Share Posted April 11, 2018 You should already know by now, that you need to post the current PLAN file, too. Link to comment Share on other sites More sharing options...
LenB10p Posted April 11, 2018 Author Share Posted April 11, 2018 No...I didn't realise that I needed to add the plan. It is now attached (hopefully). NewBuild2018Fullplan.plan Link to comment Share on other sites More sharing options...
LenB10p Posted April 11, 2018 Author Share Posted April 11, 2018 I just tried one change that seemed to work...I think. I realised that the lower front exterior wall was not set to full gable. This change seemed to make the roof plane disappear. Does that make sense? Link to comment Share on other sites More sharing options...
