SAILOR139 Posted January 1, 2018 Share Posted January 1, 2018 I exported my Home Designer Bonus Catalogs from CA Suite 2017 and imported them to a recently purchased CA Pro 2018. The catalogs were loaded into the User Catalog folder instead of the Home Designer Bonus Catalog folder in Pro 2018. How do I move them to their correct location? I wish to do the same for my Manufactured Catalogs. Sailor New 2018 Pro user; long time Suite user. Link to comment Share on other sites More sharing options...
solver Posted January 1, 2018 Share Posted January 1, 2018 Did you see my answer on ChiefTalk? Link to comment Share on other sites More sharing options...
SAILOR139 Posted January 1, 2018 Author Share Posted January 1, 2018 yes, but I do not understand why I need to re-download dozens of catalogs again. Why can't the catalogs be moved from one folder to another? If you export a catalog and import it, it should go to the correct library folder. Is this a bug? Link to comment Share on other sites More sharing options...
solver Posted January 1, 2018 Share Posted January 1, 2018 It's just the way the program works. When you export, it becomes a User Catalog, and gets imported into the User Catalog. If you have the individual .calibz files that were downloaded, they may be imported and will go into the correct spot. Link to comment Share on other sites More sharing options...
solver Posted January 1, 2018 Share Posted January 1, 2018 1 minute ago, solver said: If you have the individual .calibz files that were downloaded, they may be imported and will go into the correct spot. They can be group selected and dragged into Pro, so no need to do them one at a time. Link to comment Share on other sites More sharing options...
SAILOR139 Posted January 1, 2018 Author Share Posted January 1, 2018 Thanks, I'll do some searching, but I doubt if I have the original files. Do you have the path for the Library files? Link to comment Share on other sites More sharing options...
solver Posted January 1, 2018 Share Posted January 1, 2018 4 minutes ago, SAILOR139 said: Do you have the path for the Library files? If you are asking about the .calibz files you downloaded, they would probably be in your default Downloads folder. I would download from the website as there are changes and fixes that are incorporated into the catalogs, and the ones for Pro may be different that the ones for Suite. Link to comment Share on other sites More sharing options...
SAILOR139 Posted January 1, 2018 Author Share Posted January 1, 2018 Yes, I'm aware that the downloaded files will be in the download folder. OK I'll bite the bullet and download all of the library folders again. And, bring them into my 2018 Pro Library. Thanks for your help Link to comment Share on other sites More sharing options...
