Auto Roof Return (full return) Incomplete
jlliles87
For some reason the full return doesn't generate in in any overviews. It does show up on the floor plan though. Can anybody fill me in why? The homeowner wants a gable on that side so I inserted a wall break in line with the interior wall and set it to gable end. If I bump that section of wall out, the return will generate in overview. Not sure why this is happening considering I did the exact same thing on the backside of the house without this problem.
BRUCE THOMPSON ADDITION.plan
jlliles87,
Is this what you were trying to do with the returns? If it doesn't complete like that, you can manually adjust the length of your return in the "roof" dialogue right under the "auto roof return" box you check initially.  I had to play around a little to get the dimensions correct.
P.S., I took some liberties with your deck, hope you don't mind...
