hhunt32 Posted August 1, 2017 Share Posted August 1, 2017 Hello I am using home designer suite 2018 build 19.3.0.49OSX. I am designing a detached garage and would like to have a bonus room above the garage. I have followed the directions located here https://www.homedesignersoftware.com/support/article/KB-00904/creating-a-bonus-room-above-a-garage.html to do this but I am still having trouble getting 2nd floor wall to populate correctly. Everything appears correct and when it is viewed in 3d perspective a portion of the exterior wall on each side is absent. Could someone please help me figure out what I am doing wrong for this project? I am a homeowner attempting to design a detached garage for our home. I have included a copy of the files for review and advice. Thanks Detached Garage.zip Link to comment Share on other sites More sharing options...
solver Posted August 1, 2017 Share Posted August 1, 2017 That's a typical failing of the program. It does not know to fill in the wall there, and in Suite, I believe you will need to use one of the wedge shapes from the library sized and positioned to fill the hole. Link to comment Share on other sites More sharing options...
hhunt32 Posted August 1, 2017 Author Share Posted August 1, 2017 Thank you for your help. Link to comment Share on other sites More sharing options...
