Shawda1 Posted July 22, 2017 Share Posted July 22, 2017 Using Suite 2018. My Floor Plan view looks good. Went to Camera view, either one. And saw a few problems. Started trying to fix them. Things just started getting worse. I have about 20 hours in this plan. Floor Plan view still looks good. But the camera views all look very bad. even places I have not touched are all messed up. So I thought I would just have to start over. Even though my floor plan view still looks good. Not finished but not bad. Tried to start over with a new plan but the Auto Dimension s don't work and I can't turn them on. I don't know what else to do but reinstall the software. Any Ideas. Hard to draw without seeing the dimensions. Link to comment Share on other sites More sharing options...
bluesparrowllc Posted July 22, 2017 Share Posted July 22, 2017 What, exactly, is wrong with the camera views? Could you post a screen shot so we can see what's going on? Also, please fill out your signature with your version for future posts. Link to comment Share on other sites More sharing options...
Shawda1 Posted July 22, 2017 Author Share Posted July 22, 2017 I some cases exterior walls look like they are there are missing. You may see a window or door but no wall. On interior views, you see right through walls to the outside. I am trying to redraw walls that look like they are fine. Getting errors about ceiling height. I'll see what I can do about a screen shot. Any Ideas on how to get my Auto dimensions back? Again Floor Plan looks OK Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 22, 2017 Share Posted July 22, 2017 Camera views are not like the Human Eye in that if you place a camera viewpoint too close to a wall, it merely cuts through that wall you are too close to. That is "Usual behavior" and that is probably what you are seeing. If something is visually missing but you know it is there, it is probably on a named layer that can be found alphabetically in a "Display Options" dialog found under "Tools - Display Options". . Plan view and each camera view has its own "Display Options" dialog when that camera view is active. So in plan view or any particular camera view visual objects can be "turned on or off" at your command. Take a look and see if your missing dimensions are just "turned off" or unchecked in Display Options. DJP Link to comment Share on other sites More sharing options...
