3307613100 Posted May 19, 2017 Share Posted May 19, 2017 I'm designing a Sunroom, which has a variety of rectilinear windows and sliders that consumes all four walls. I've programmed one wall as a gable wall so I can add an arched window above the rectilinear windows (South wall). One problem I'm running into with is when I view the Sunroom in plan view I see both the rectilinear windows and the arched windows, which looks really messy. Technically, I shouldn't see the arched window because it's above 4'-0", which is the "cut line" for a floor plan. Does anyone know if it's possible to hide the arched window in plan view? With that in mind, does anyone know how to hide the roof outline as well? I only want to view the floor plan. I've attached a picture for your reference. You can clearly see the roof line, as well as the messy view of the arched windows overtop the rectilinear windows (South end of the Sunroom). Thanks guys. Chelsea P.S. This is my first project working in Home Design Architectural. Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 19, 2017 Share Posted May 19, 2017 What I do when I have transom windows is to stagger the window labels , depending upon what software title you have the window labels should be selectable in plan view and left-click-select-dragged so that they are not on top of each other so anyone can then see that there are stacked windows and what size they are. DJP Link to comment Share on other sites More sharing options...
