Sign in to follow this
SeniorCali
pdf printing on mac
Post the plan as it can be a number of things i.e. what you sent to the layout is larger than the sheet.
I agree with D. Cortes in that you have given so little information it is hard to give useful advice in exchange for your asking for help. The rest of us just print to PDF without incident so there is probably something YOU are doing that is the problem since the process is simple and straightforward. What paper size are you printing to? Did you make sure that your .layout file is properly size formatted to mirror your orientation and paper size? Are you printing to color or black and white? etc. etc. What software title and version are you currently using?
Just a quick question.  When I choose Print (PDF), how do I print all three levels of the house?  I seem to be able to only print the level that I am on.
1) Please fill out your Signature -- see below.
2) What type of view are you wanting to print -- plan, elevation, 3D ...
Posting an image or 3 often helps fill out a skimpy description.
It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and this info is often key to providing a good suggestion
Resources for self help:
