Flipping objects
pgjacob
I am trying to fill a cocktail glass. All the glasses in the library are empty.  I know this is a small detail but now I just want to know if it is possible...I found a half sphere/dome but it is upside down.  How do I flip it so it will look like liquid in a round glass??
Flipping objects cannot be done in Home Designer titles. It can be done in Chief Premier. An alternate solution would be to make your glass fill in Sketch Up and then import into whatever you have. (You really should do as Eric requests and let us know what software you have and use), it makes a big difference as to useful answers you get.
Thanks!  I am using Home Designer Pro 2017.  I have edited in signature.
I found the sphere/dome just searching library.
For David Potter, I see you are in Austin.  I am using this software to build a house in your area.  I am not an architect or a builder so just playing around with software.  Although I am getting hooked.
