AnnetteWebb Posted February 8, 2017 Share Posted February 8, 2017 I am unable to place a soffit or use the soffit tool. I get this message I could not find any info on this error Any suggestions appreciated Link to comment Share on other sites More sharing options...
solver Posted February 8, 2017 Share Posted February 8, 2017 Where are you trying to place the soffit? Are you able to place it outside the structure? Link to comment Share on other sites More sharing options...
katalyst777 Posted February 8, 2017 Share Posted February 8, 2017 Did you change your Soffit defaults? If so, maybe go back in and make the default one smaller (you can also resize them after they are placed in the plan). Double check your Ceiling Height in the room. Failing that, attach the plan and we'll take a look. Link to comment Share on other sites More sharing options...
AnnetteWebb Posted February 8, 2017 Author Share Posted February 8, 2017 I have not been able to place soffit anywhere. I was trying to place over the refrigs, but when I received the error message, I tried other areas and received the same message Areas tried...ceiling, floor, outside, over upper cabinets ...anywhere The first pic is the default settings I believe. THANKS Link to comment Share on other sites More sharing options...
AnnetteWebb Posted February 8, 2017 Author Share Posted February 8, 2017 Ceiling height settings for 1st fl Link to comment Share on other sites More sharing options...
katalyst777 Posted February 8, 2017 Share Posted February 8, 2017 Floor to Top is set to 99" for your default soffit, but your ceiling (94 3/4) is shorter than that. What happens if you set the Soffit Default Floor to Top to something like 90" instead? 2 Link to comment Share on other sites More sharing options...
AnnetteWebb Posted February 8, 2017 Author Share Posted February 8, 2017 Thank you, Kat. Thanks for catching that. it did the trick! Link to comment Share on other sites More sharing options...
AnnetteWebb Posted February 8, 2017 Author Share Posted February 8, 2017 Yes mame Link to comment Share on other sites More sharing options...
