Surveyor Bearing Display
447Debbie
When you select them, the layer they are on is displayed in the status bar.
They may be on a generic layer with other things you don't want to turn off, so you could try changing the text to be white and very small, for example.
Can you open the item itself? Select it and Control-E. If so, there should be options there.
I imagine there are other items on that layer that you do not want to change, so you probably don't want to make a change at the layer level.
What I ended up doing is I turned off the CAD layer long enough so the text would go away.  Then I was able to join my walls.  Then I turned the CAD layer back on.  My biggest issue is that it was covering up a point where two walls had to join and I couldn't see the join area.  Turning off the CAD display got that accomplished.  Sure would be nice to be able to edit that text, though I was able to work around it.
