Sign in to follow this
Debbrett
making an overall change to a plan that is in process
I've started creating my floor plan and have decided to change the construction to ICF on all exterior walls and foundation.  Is there a way to tell the program to change them all without having to redesign?  Like a change all?  I did change my default settings for exterior walls to ICF, found that by accident, so now I can continue in that style, but the existing plan is regular construction and would like to be able to easily adjust those all to ICF.
My product is Home Design Suite 2017.
Please take a minute and fill out your signature -- see below. Knowing what software you are using is often key to providing a suggestion.
I believe with Suite, you will need to change each wall, no way to change in mass.
It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click My Settings, then Signature on the left.
Resources for self help:
Like solver said, you have to change each wall. If your not to far into the plan, start over the with new wall defaults.
Always set the defaults first, before building anything.
