questisition Posted October 4, 2016 Share Posted October 4, 2016 i have a problem trying to follow the plant shelf directions where it worked okay on one side of my plan, but the material doesnt line up on the other does anyone know how to fix this im using the interiors version if that matters Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 5, 2016 Share Posted October 5, 2016 Post a copy of your plan, we are not psychic here so you need to share the plan with us for a lucid response. DJP 2 Link to comment Share on other sites More sharing options...
katalyst777 Posted October 5, 2016 Share Posted October 5, 2016 The Pro version allows you to make a copy of materials and modify their offset (where the material starts) to adjust where tile or brick starts along a wall to make it look more consistent. Does Interiors have this option? 1 Link to comment Share on other sites More sharing options...
Solution questisition Posted October 5, 2016 Author Solution Share Posted October 5, 2016 thank you kat it does not but i decided to use a different material at the other direction this will work for me Link to comment Share on other sites More sharing options...
larana Posted October 10, 2016 Share Posted October 10, 2016 This looks great! You should post the finished product in this other thread when you've got it all detailed out!https://hometalk.chiefarchitect.com/index.php?/topic/2696-show-off-your-renderings/ Link to comment Share on other sites More sharing options...
questisition Posted October 10, 2016 Author Share Posted October 10, 2016 On 10/10/2016 at 4:34 PM, larana said: This looks great! You should post the finished product in this other thread when you've got it all detailed out! https://hometalk.chiefarchitect.com/index.php?/topic/2696-show-off-your-renderings/ okay thanks Link to comment Share on other sites More sharing options...
