rfcomm2k Posted September 15, 2016 Share Posted September 15, 2016 In the attached floorplan, a second floor wall will not show the exterior wall material. I have tried using the eyedropper and repainting the surface. I have tried changing the material. I have tried moving the wall in and out. I have deleted the wall and drew it back in. Nothing works. It just refuses to accept the wall material. block diagram 4A3a floorplan with landscaping.plan Link to comment Share on other sites More sharing options...
Jo_Ann Posted September 15, 2016 Share Posted September 15, 2016 Not showing up in the downloaded plan. But I think that if you slightly pull back the edge of the 1st floor roof plane, the problem will go away. Link to comment Share on other sites More sharing options...
solver Posted September 15, 2016 Share Posted September 15, 2016 That looks like the roof needs to be pulled back a bit. Also, make sure the walls are aligned between floors. Link to comment Share on other sites More sharing options...
rfcomm2k Posted September 15, 2016 Author Share Posted September 15, 2016 You two are GENIOUSES! But I NEVER manually changed the roof plane, so IDK how this got started. Thanks for this fix! Link to comment Share on other sites More sharing options...
