MauiMike Posted August 15, 2016 Share Posted August 15, 2016 I have a straight driveway leading to a circular driveway and would like to add a 'curving concrete area' so I can make the turn into and out of the driveway more easily (see up to red curve in picture). Is that possible? Thanks! Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 15, 2016 Share Posted August 15, 2016 yes, use the CAD tools to curve the sides the use a poly line driveway object. DJP Link to comment Share on other sites More sharing options...
MauiMike Posted August 15, 2016 Author Share Posted August 15, 2016 On 8/15/2016 at 6:03 AM, DavidJPotter said: yes, use the CAD tools to curve the sides the use a poly line driveway object. DJP Thanks for the tip--you directed me to look in the right place, and I was able to make the change I wanted (though it's hard to be very accurate to move around little lines in a nice and even curve). See attached picture. Link to comment Share on other sites More sharing options...
katalyst777 Posted August 16, 2016 Share Posted August 16, 2016 You can create pretty much any shape using the Change Line/Arc and Break Line edit buttons. This article has a good explanation. It uses road markings but pretty much the same steps apply to any closed polyline based objects in this software.https://www.homedesignersoftware.com/support/article/KB-00864/creating-road-markings.html Link to comment Share on other sites More sharing options...
MauiMike Posted August 17, 2016 Author Share Posted August 17, 2016 On 8/16/2016 at 3:07 PM, katalyst777 said: You can create pretty much any shape using the Change Line/Arc and Break Line edit buttons. This article has a good explanation. It uses road markings but pretty much the same steps apply to any closed polyline based objects in this software. https://www.homedesignersoftware.com/support/article/KB-00864/creating-road-markings.html Very helpful link--many thanks! Link to comment Share on other sites More sharing options...
