DIY_Guy Posted August 4, 2016 Share Posted August 4, 2016 Due to my infrequent use of this software I keep forgetting most of what I've learned over the years, so I apologize for my only contributions to this forum being a question or two every 6 to 12 months. I'm going to be replacing my existing HVAC system with one larger system or two separate systems. I'd like to email my house plans to various HVAC contractors to solicit pricing, but before I do so I'd like to show them where all my current floor registers are. Since sending these plans out to bid are the only reason for me to be showing these floor registers on my plans, I'd like to be able to turn off the layer that they will reside on. I found 'floor registers' in the 'Ventilation' section of the Library Browser and I can add them to my plan just fine, but they don't turn off when I turn off the 'HVAC' layer. How can I find out what layer these floor registers are on and is there anyway for me to change which layer they are on, as I'd like them to be on the 'HVAC' layer? Also, as far as positioning these registers accurately in the various rooms. Is there an easy way to do that. I remember some objects actually show various dimensions when you select them and then you can click on one of those dimensions, change it, and the object will automatically move. Again, because I use this software so infrequently I don't remember how to do that. Thanks, Spence Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 4, 2016 Share Posted August 4, 2016 positioning is done with manual dimensions (that is the way I do it in Premier). Layer control is not something that is available in Pro, sorry but you can get your job done by turning layers on and off in Display Options. DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted August 8, 2016 Share Posted August 8, 2016 When you select an object, the status bar at the bottom of the program's screen tells you what layer it is on.Since you can't move objects to a different layer in Pro like you can in Premier, you might just want to use File> Save As to create a copy of the plan with all of that stuff added in.KB-00487: Positioning Objects Precisely Using Dimensions Link to comment Share on other sites More sharing options...
