belmont Posted June 21, 2016 Share Posted June 21, 2016 Hi, I am working on a kitchen design in an existing old house. Currently, there is a stairway going up on the back side of the kitchen wall that causes part of the ceiling to be angled to match the underside of the stairs in the kitchen. I created this portion of angled ceiling with a soffit, but I can't figure out how to close the side and run crown around the top of it. It ends about 8" from a wall, so it will need to be stretched out to that wall for the purposes of crown. Any suggestions? Link to comment Share on other sites More sharing options...
solver Posted June 21, 2016 Share Posted June 21, 2016 If you are asking about the triangle shape above the angled soffit, use the inverted wedge shape from the library. Link to comment Share on other sites More sharing options...
katalyst777 Posted June 21, 2016 Share Posted June 21, 2016 Your signature says you have Pro, so I would recommend using a Ceiling Plane instead of a sloped soffit. Link to comment Share on other sites More sharing options...
