cte677 Posted May 26, 2016 Share Posted May 26, 2016 Home Designer Pro 2017 I am attempting to have step down concrete sections using break wall / pony walls ... see "Step concrete front.jpg" attachment. I can split the wall into multiple segments. However when I set the segments to different pony wall heights, the break wall lines disappear ... see "Step concrete top.jpg" attachment. Also, when I attempt to move the break wall line closer to the corner, it snaps to the corner. The .plan is attached. Please advise. Also, is there a way to disable the auto rebuild wall? Thanks! House 160525 03 no interior.plan Link to comment Share on other sites More sharing options...
solver Posted May 26, 2016 Share Posted May 26, 2016 Draw the pony wall. Take an elevation. Select the upper or lower part of the wall, break it with the break tool (3 on the keyboard), shape as needed. Link to comment Share on other sites More sharing options...
cte677 Posted May 28, 2016 Author Share Posted May 28, 2016 One thing that helps, is to use Manual Dimension for locating the break wall line. After changing the pony wall height, the Manual Dimension defines the break wall location. It would be good if Chief Architect fixed this ... did not erase the break wall line with adjacent pony walls. The attachment shows a concrete step wall that is not rare. Link to comment Share on other sites More sharing options...
