aussuab Posted April 19, 2016 Share Posted April 19, 2016 How can I create this style? Link to comment Share on other sites More sharing options...
solver Posted April 19, 2016 Share Posted April 19, 2016 What, specifically, are you asking about? Link to comment Share on other sites More sharing options...
Solution katalyst777 Posted April 19, 2016 Solution Share Posted April 19, 2016 Like solver, I'm not totally sure that I follow quite what you're asking.If it's about the first floor, I would probably use an arched Doorway opening, not columns to create this.If it's about all the little railings, depending on your version (you may want to add this to your signature to avoid having to tell us each time) then you can probably just use Railings set to use Panels set to something under Architectural> Fences & Railings> Turned.If it's not either of those things, well, then I think we're going to need more info? Link to comment Share on other sites More sharing options...
katalyst777 Posted April 20, 2016 Share Posted April 20, 2016 You should also check out your other carport post where Jo_Ann did a better example of creating the arched openings.https://hometalk.chiefarchitect.com/index.php?/topic/2280-carport/?p=12753 Link to comment Share on other sites More sharing options...
aussuab Posted April 25, 2016 Author Share Posted April 25, 2016 thank you! Link to comment Share on other sites More sharing options...
