Curved Columns
aussuab
Go to solution Solved by katalyst777,
  • Solution
Like solver, I'm not totally sure that I follow quite what you're asking.
If it's about the first floor, I would probably use an arched Doorway opening, not columns to create this.
If it's about all the little railings, depending on your version (you may want to add this to your signature to avoid having to tell us each time) then you can probably just use Railings set to use Panels set to something under Architectural> Fences & Railings> Turned.
If it's not either of those things, well, then I think we're going to need more info?
