LaGalaxy Posted April 16, 2016 Share Posted April 16, 2016 What are all my interior 4 & 6 walls ends unfinished? I modified the layers to add paint, so I am assuming its because of that but I can't see why. Did I do it right? Link to comment Share on other sites More sharing options...
solver Posted April 17, 2016 Share Posted April 17, 2016 That's a common problem, and is often caused by what's at the top of the wall. Posting your plan file -- make sure it is not open in Home Designer, will help us do more than guess. Link to comment Share on other sites More sharing options...
LaGalaxy Posted April 17, 2016 Author Share Posted April 17, 2016 The only thing above is an empty 2nd floor. I'll post the plan shortly.. Link to comment Share on other sites More sharing options...
LaGalaxy Posted April 17, 2016 Author Share Posted April 17, 2016 Here is the plan... plan.plan Link to comment Share on other sites More sharing options...
solver Posted April 17, 2016 Share Posted April 17, 2016 Consider removing the paint layers you added to the walls. Define the wall via Defaults, adding color via the Materials panel. You might also rebuild the stairs so the 2 flights and landing are all one.Draw the bottom flight, the top flight, then click where the landing goes to create it. Link to comment Share on other sites More sharing options...
LaGalaxy Posted April 17, 2016 Author Share Posted April 17, 2016 OK Ill give it a shot, thanks.. Link to comment Share on other sites More sharing options...
Fidellaty Posted April 17, 2016 Share Posted April 17, 2016 I deleted the paint layers and that made the wall ends finished. But you are right, there seems to be a problem. Maybe something wasn't set to display. From the directions I found it looks like you did it right. Link to comment Share on other sites More sharing options...
Fidellaty Posted April 17, 2016 Share Posted April 17, 2016 I tried adding the paint color using a thickness of 1/16" and it seems to have solved the problem. Maybe? Link to comment Share on other sites More sharing options...
solver Posted April 17, 2016 Share Posted April 17, 2016 I tried adding the paint color using a thickness of 1/16" and it seems to have solved the problem. Maybe? That works, but now the walls are thicker. You could reduce the thickness of another layer, like the drywall. Link to comment Share on other sites More sharing options...
Fidellaty Posted April 17, 2016 Share Posted April 17, 2016 Done. Link to comment Share on other sites More sharing options...
LaGalaxy Posted April 22, 2016 Author Share Posted April 22, 2016 Thanks all, I'll try that out.. Link to comment Share on other sites More sharing options...
