Wall Plates at Roof Trusses
lmorris
I recently made adjustments to my defaults so trusses would be built with a 12" energy heel.
Seems to have worked well except the wall framing now has a double top plate at the bottom of the trusses as well as another double top plate 12" above that as if another small wall was built on top of the main wall.
Haven't yet figured out why or how to fix things so that my typical wall stops at the bottom of the truss.
Any suggestions?
Thanks
As a question, this should go in Q&A. Tips & Techniques is for tips and techniques.
Do you want the lower double top plate? -- as opposed to a single.
Please post a plan file that illustrates the problem.
I understand the single or double top plate but as per attached "Wall Framing-1" after installing a truss the wall looked fine but rebuilding wall framing after the truss caused an extension to the wall framing as per "Wall Framing-2".
Trying to add trusses with energy heels without affecting the wall framing but can't seem to figure it out.
Thanks
Wall Framing-1.pdf
Wall Framing-2.pdf
