heyseano Posted March 20, 2016 Share Posted March 20, 2016 Hello I little direction if I may. I have my Plan and I can send elevations to layout It assumes the building pad is flat so I can insert a cad angled line to mimic the fall of the land and insert some elevation data for levels Ideally I would like to just send the elevation to layout with all the fall lines complete so it shows the cladding etc between floor level and ground I can set up terrain perimeters and elevation data to show the fall but it is the building structure between floor and ground where I am lost Maybe create a basement and then eye drop the cladding to the subfloor ? Maybe create foundation ? Thoughts much lay appreciated Had pro very powerful so far Sean Link to comment Share on other sites More sharing options...
solver Posted March 20, 2016 Share Posted March 20, 2016 What is missing when you send an elevation to layout, other than the line indicating slope of the land? Link to comment Share on other sites More sharing options...
heyseano Posted March 20, 2016 Author Share Posted March 20, 2016 The building structure between the floor and the ground Link to comment Share on other sites More sharing options...
solver Posted March 20, 2016 Share Posted March 20, 2016 Could you post your plan? An elevation will include that portion of the building, if there is one, and the entire elevation will be sent to layout. Link to comment Share on other sites More sharing options...
heyseano Posted March 21, 2016 Author Share Posted March 21, 2016 HI Eric Attached is the elevations. Hopefully you can see what I mean where the house sort of sits up in the air with the ground line drawn in via a CAD line below. I could manipulate these elevations a little with more CAD lines but ideally I would like to 'do it right' Thanking you Sean Combined Dwelling elevations.layout Link to comment Share on other sites More sharing options...
solver Posted March 21, 2016 Share Posted March 21, 2016 Need to see the Plan file, not the Layout. Link to comment Share on other sites More sharing options...
heyseano Posted March 23, 2016 Author Share Posted March 23, 2016 Eric Here is my plan file. The elevation in the layout is in the previous post which shows the floor up in the air so to speak with no structure between floor and ground. Hope you can see what I mean and offer and easy fix or solution to make the elevations look better. Sean 22 Merideth Principal dwelling (7).plan Link to comment Share on other sites More sharing options...
solver Posted March 23, 2016 Share Posted March 23, 2016 You need to build a Foundation. Build>Floor>Build Foundation Also, you should set the proper room type for at least some of the rooms. Your garage and front porch both show wood floor and trim as if they were interior rooms. Foundation with default settings. Link to comment Share on other sites More sharing options...
