BeachGirl Posted March 6, 2016 Share Posted March 6, 2016 I am trying to design a home where the main part of the home is on a 5 ft crawl space with a step down to an enclosed breezeway (heated/cooled) on slab which connects to the garage and other living space also on slab. In HD Pro how can I accomplish this change in foundation? Thanks for the help! Noel Link to comment Share on other sites More sharing options...
BeachGirl Posted March 7, 2016 Author Share Posted March 7, 2016 I have tried searching all the available help options with no luck...perhaps I am not using the correct verbiage. I am using Home Designer Pro 2016. When I check monolithic slab, I get the slab but it is hanging in the air at the same height as the main part of the house on crawl space. Thanks, Noel Link to comment Share on other sites More sharing options...
Solution solver Posted March 7, 2016 Solution Share Posted March 7, 2016 You can adjust the floor height in the Room Specification dialog. Enter a negative number to lower the floor. Link to comment Share on other sites More sharing options...
BeachGirl Posted March 7, 2016 Author Share Posted March 7, 2016 Thanks - obvious is not always so obvious! Link to comment Share on other sites More sharing options...
