Floors
KoenColen
Go to solution Solved by katalyst777,
Hi,
I have 2 rooms next to each other. There is a small step between the 2 rooms.
So one room starts slightly higher from the terrain than the other.
Is this considered a new floor?
Or are there any parameters I can play with to adjust where the floor starts?
Hope I am clear here.
Thanks!
No, it is merely a slightly different floor level, it can be lower than the rest of the first floor or slightly higher than the first floor. You make the change by drawing a wall to divide the two rooms setting one different from the adjacent one.
