FlightDeck Posted February 17, 2016 Share Posted February 17, 2016 Hi, I saw a post on this from 2014 but the "solution" wasn't clear. I've noticed since using Pro that the default zero-thickness Room Dividers keep converting themselves into invisible walls with the thickness of a default wall. I can't be certain but it seems to do it when re-opening a plan or maybe using Undo. I never recall seeing this issue in HDA. How do I make it stop doing this? Thanks Link to comment Share on other sites More sharing options...
solver Posted February 17, 2016 Share Posted February 17, 2016 Happens to me all the time. The solution posed over on ChiefTalk is to make your own "Room Divider" wall. Create a wall with a single layer, as thin as possible, with Insulation Air Gap as the material. This will always happen when floor/ceiling heights differ between the 2 spaces. 2 Link to comment Share on other sites More sharing options...
FlightDeck Posted February 17, 2016 Author Share Posted February 17, 2016 Thanks Eric. Nice to know I'm not going crazy! (Well I am, but for other reasons! ) Sometimes I've tried altering the thickness back to zero but it rarely works. Will give defining the wall type a try. It's bizarre I didn't have this happen in HDA. Maybe somehow none of my HDA models had the issue that triggers it. Link to comment Share on other sites More sharing options...
katalyst777 Posted February 17, 2016 Share Posted February 17, 2016 From the program's Help:If a zero-thickness Room Divider separates two rooms with different floor and/or ceiling heights, its wall type will be changed to the current plan’s default Interior Wall so that the platform step created by the height difference can be enclosed. 4 Link to comment Share on other sites More sharing options...
FlightDeck Posted February 17, 2016 Author Share Posted February 17, 2016 Thanks Kat. Oddly enough this isn't the case. They are however below a room that is "Open Below". I wonder if that's another trigger. Link to comment Share on other sites More sharing options...
katalyst777 Posted February 17, 2016 Share Posted February 17, 2016 If you have an "Open Below" room, then it definitely will have to generate a platform, which from my understanding will trigger the wall type changing for a Room Divider. Link to comment Share on other sites More sharing options...
FlightDeck Posted February 17, 2016 Author Share Posted February 17, 2016 Not in my case. Even though both sides of the room dividers have an Open Below room above them, both sides have identical floor and ceiling heights. (In this case the room dividers are being used purely as a workaround to permit different mouldings on different walls in the same room, as discussed here https://hometalk.chiefarchitect.com/index.php?/topic/1868-disable-mouldings-on-individual-walls-in-a-room/). These dividers are however ending at complex corner junctions of multiple walls of differing types/thicknesses, and I've found these corners are always problematic particularly when editing things. It's possible that the room dividers are looking at floor/ceiling heights on the other side of these corners and seeing differing heights that way. Link to comment Share on other sites More sharing options...
