John_T Posted February 15, 2016 Share Posted February 15, 2016 I am just getting started (exterior wall) but cannot find how to set a wall length - so it will not be dependent on a wall I add later? Currently every time I add a wall it changes the prior wall length. Link to comment Share on other sites More sharing options...
katalyst777 Posted February 15, 2016 Share Posted February 15, 2016 The way this software works is with connected walls. Get the overall shape right first, then precisely position the walls relative to each other using dimensions. (Go through the User's Guide under your Help menu if you haven't already, it does a good job of explaining this.)This video helps to explain as well.https://video.homedesigner.chiefarchitect.com/?search=move+walls 2 Link to comment Share on other sites More sharing options...
hummin Posted February 15, 2016 Share Posted February 15, 2016 Coming from a CAD background, I was confused by how this software works with regards to inputting walls as well at first, but it works if you can set aside your preconceptions of how you think it should function and don't fight the design. This online resource is one that explains how. https://www.homedesignersoftware.com/support/article/KB-00245/setting-exact-wall-dimension-lengths.html Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 16, 2016 Share Posted February 16, 2016 This You Tube Dimensions tutorial may help you: https://www.youtube.com/watch?v=U6mra1PpSL8 DJP Link to comment Share on other sites More sharing options...
