jonnyo53 Posted February 12, 2016 Share Posted February 12, 2016 I am trying to create a split entry floor plan with garage. I cannot figure out how to draw the garage at a lower height than the split entry house. any suggestions? Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 12, 2016 Share Posted February 12, 2016 After you have your split entry house done you draw your garage, manually setting its "Floor" level where you need it relative the entry and then manually set its ceiling height, when everything is properly set, then build roofs. If you need to you can work out the relative heights on paper to figure out the settings you need (guessing takes longer). DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted February 15, 2016 Share Posted February 15, 2016 KB-00269: Creating a Split Level Entry KB-02947: Creating a Split Level Structure 1 Link to comment Share on other sites More sharing options...
