English Posted February 9, 2016 Share Posted February 9, 2016 I've been working on a plan and had issues with my second and third floors so I deleted them and started over with just the first floor. I created a new second floor with no auto build. I added a couple of external walls and aligned them with the walls below. When I go to the second floor dollhouse view there are no walls visible. Okay I deleted the floor and created a new floor with auto walls turned on. It created the second floor on the first floor. Could someone please take a look at my plan to see what's going on. Thanks Alan Inverness.planFetching info... Link to comment Share on other sites More sharing options...
solver Posted February 9, 2016 Share Posted February 9, 2016 Use Edit>Edit Area>Edit Area to copy the first floor plan. Open a new plan and paste it. Build a 2nd floor. Link to comment Share on other sites More sharing options...
katalyst777 Posted February 9, 2016 Share Posted February 9, 2016 You've set your Floor Defaults wrong.For example, your Floor 1 Defaults have the Ceiling at 0", no Floor or Ceiling Finishes, etc.That's why copy/paste in to a new plan as solver's recommended will work, because the Floor 1 defaults there will be standard. 2 Link to comment Share on other sites More sharing options...
English Posted February 9, 2016 Author Share Posted February 9, 2016 Eric Okay I did that but now some of my second floor walls are floating and some are not visible. Alan Inverness.planFetching info... Link to comment Share on other sites More sharing options...
English Posted February 9, 2016 Author Share Posted February 9, 2016 On 2/9/2016 at 5:23 PM, katalyst777 said: You've set your Floor Defaults wrong. For example, your Floor 1 Defaults have the Ceiling at 0", no Floor or Ceiling Finishes, etc. That's why copy/paste in to a new plan as solver's recommended will work, because the Floor 1 defaults there will be standard. Kat I have no idea how those got changed. Alan Link to comment Share on other sites More sharing options...
katalyst777 Posted February 9, 2016 Share Posted February 9, 2016 The new plan doesn't have an enclosed space on Floor 2 to make a room, so the roof planes building over the Bow window from Floor 1 are going to cut off some of the walls on Floor 2. 1 Link to comment Share on other sites More sharing options...
English Posted February 9, 2016 Author Share Posted February 9, 2016 On 2/9/2016 at 5:37 PM, katalyst777 said: The new plan doesn't have an enclosed space on Floor 2 to make a room, so the roof planes building over the Bow window from Floor 1 are going to cut off some of the walls on Floor 2. I noticed that Kat --- need to get the walls finished before building the roof. Any ideas why the gaps between some walls in elevation? I added some more walls but am having an alignment issue. If I align the second floor with the first and look at the doll house view there is a definite misalignment of about 3". Thanks Alan Link to comment Share on other sites More sharing options...
solver Posted February 9, 2016 Share Posted February 9, 2016 Make sure they are aligning to the correct layer. You changed some settings while working on your house, I believe. Don't know if these are preferences or defaults. When I added a 2nd floor here, there were no misalignments. My 2nd floor also formed a room. Link to comment Share on other sites More sharing options...
katalyst777 Posted February 9, 2016 Share Posted February 9, 2016 I'm not seeing a gap, but your custom "Exterior Stone Wall" wall type is set up in a rather odd fashion (vapor barrier on the inside of the framing and no drywall?).Like solver, if I generate a new Floor 2 in your most recent plan it does create a completed enclosed space. Link to comment Share on other sites More sharing options...
English Posted February 9, 2016 Author Share Posted February 9, 2016 Kat Yes I have plans for that wall. The vapor barrier goes on the inside of the framing -- well on all the walls I've ever built it does. I did check the two wall types - my custom and the 4" Stucco and they all align to the main layer -- the studs. I'll check again tomorrow though. Thanks Alan Link to comment Share on other sites More sharing options...
English Posted February 10, 2016 Author Share Posted February 10, 2016 Here is a cross section of the wall that doesn't sit on top of the floor below. I have to manually stretch each wall polyline to close the gap. This has nothing to do with the wall misalignment. Alan Link to comment Share on other sites More sharing options...
solver Posted February 10, 2016 Share Posted February 10, 2016 Here is one that seems clean. Inverness (Eric).zipFetching info... Link to comment Share on other sites More sharing options...
English Posted February 10, 2016 Author Share Posted February 10, 2016 Thanks Eric -- I'll look at that. It seems as if they come and go. I look at the doll house view and see the gaps and a while later they have corrected them selves. Alan Link to comment Share on other sites More sharing options...
solver Posted February 10, 2016 Share Posted February 10, 2016 On 2/10/2016 at 8:47 PM, English said: It seems as if they come and go. Happens to me all the time. One minute there is a hole somewhere, next time I look it's gone, only to return later. Link to comment Share on other sites More sharing options...
English Posted February 11, 2016 Author Share Posted February 11, 2016 On 2/10/2016 at 9:07 PM, solver said: Happens to me all the time. One minute there is a hole somewhere, next time I look it's gone, only to return later. Oh I thought it was me. Alan Link to comment Share on other sites More sharing options...
