BuilderKen Posted January 26, 2016 Share Posted January 26, 2016 somehow I have done something that results in a very small perspective (like camera is very very far away) when I try to use the 3 D perspective tool. I noticed when I sent the plan to layout that the plan has extremely long vertical boundaries, which I think is causing the problem. Any ideas on how to get the plan boundaries reduced so I can rotate the perspective normally? I have attached a pdf picture of the dot of the plan when I open the persective Sedgwick v. 1.5-Perspective Full Overview Image problem.pdf Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 26, 2016 Share Posted January 26, 2016 This caused by a small segment of wall or some other object accidentally created by you while working on your plan. So when you order a "fill screen" or "overview camera" the accidental object causes the unwanted appearance. Find and remove the accidental object and then things will return to normal. DJP Link to comment Share on other sites More sharing options...
English Posted January 26, 2016 Share Posted January 26, 2016 David I remember when I was working with AutoCAD drawings that were shared among designers. Some wag would go way out in left field and put a dot or some other very small object. When the next guy that worked on it did a View Extents the main area of work was minuscule and it took a while to find the errant object. Alan Link to comment Share on other sites More sharing options...
katalyst777 Posted January 26, 2016 Share Posted January 26, 2016 KB-00998: Troubleshooting why a Structure Appears Small and Distant in a Full Overview or Dollhouse Camera View 1 Link to comment Share on other sites More sharing options...
