jeffreybianchi Posted January 24, 2016 Share Posted January 24, 2016 I'm using HD Pro 2015. Is anyone aware of any way to represent 3-D gable trim (such as what's pictured on the attached photo? There doesn't appear to be anything in the library, and 3D Warehouse doesn't really have anything either. I would normally use my best friend - the soffit tool - but to the best of my knowledge you can't rotate soffits vertically. Thanks in advance. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 24, 2016 Share Posted January 24, 2016 Two ways: 1. make it manually using custom shaped soffits or 2. make it in Sketch UP an then download and import DJP Link to comment Share on other sites More sharing options...
jeffreybianchi Posted January 24, 2016 Author Share Posted January 24, 2016 David: Thanks! I just discovered the "sloped" soffit option in the soffit menu, when you refer to "custom shapes" is there another tool that I'm missing or are they one and the same? JPB Link to comment Share on other sites More sharing options...
