Delete floor but keep terrain
Joe_Mech_O
Hi Eric,
Thanks for the tip.  It seems to work in as far as moving the terrain details to the other floor, but when I go to the orthographic view, the terrain is not there.  If I undo the move, it shows up on the ortho view no problem.  Not sure how to proceed.
Hey Eric,
Before I try moving structure from floor 1 to floor 2, then deleting floor 1, you say there is another way if I am using Pro.  I am indeed using Home Designer Pro 2016, so if there is another way (easier perhaps), I would love to try it.
Thanks for your help and patience.
I'd just move the structure, but in Pro, right click on the terrain perimeter after it's moved to floor 1. Select Convert Polyline, then choose Terrain Perimeter.
This may make the program see this as a Terrain.
Otherwise, Edit>Edit Area>Edit Area (All Floors) to move the building to floor 2, then delete floor 1.
Do this in a copy of your plan just in case.
