FlightDeck
Door/sidelight panel curtains
Hi all,
Is the option for putting panel curtains on doors (or door sidelights) available in the software?  I'm thinking of the type that has both a top and bottom rod holding them in place, for example:
http://s7d9.scene7.com/is/image/BedBathandBeyond/5747023264404g
I couldn't find a built-in way to do this.  It appears I need to work around it by freely placing a curtain object from the library and sizing/locating it so as to coincidentally align with the doors, particularly open doors.  If this is the only method, is there a way to make it snap/stick to the doors so that they will stay together when doors are open / closed at various angles?
Thanks and regards,
I do not think such curtain symbols exist, if they exist they would be here ( https://3dlibrary.chiefarchitect.com/index.php?r=site/library&search=&x=0&y=0&x=true&soft_family_2=2&hid_soft_family_2=2&utm_source=&utm_medium=&utm_campaign= ) and or you can do a "search" at 3D Warehouse where you might find a usable symbol there you can download for free (no guarantees as to quality)
Thanks David.  Any suggestions for my second question?  Currently I'm manually placing the curtain object to align with the door's open angle.
