TonyRichardson Posted December 9, 2015 Share Posted December 9, 2015 When using metric dimensions, the underlying grey grid on floorplan views is 1 metre square. Since many houses are designed on multiples of 90cm "bays", is it possible to change the underlying grid to 90cm square to make it easier to line up walls, beams, windows etc. Link to comment Share on other sites More sharing options...
solver Posted December 10, 2015 Share Posted December 10, 2015 Did you try searching the built in help for Reference Grid? Link to comment Share on other sites More sharing options...
Solution TonyRichardson Posted December 10, 2015 Author Solution Share Posted December 10, 2015 Thanks Solver, I never would have found this method buried deep in the menus (I was looking under Preferences). I was able to change the Reference Grid (I didn't know what this was called before) to 900mm square, but now it doesn't line up with my design. I can't find a way to shift the entire plan to line up with the grid, but at least I now know how to do it for future designs. Link to comment Share on other sites More sharing options...
solver Posted December 10, 2015 Share Posted December 10, 2015 See this thread on ChiefTalk discussing the alignment issue. Link to comment Share on other sites More sharing options...
