bigriles Posted November 30, 2015 Share Posted November 30, 2015 must be a simple way to lower the height of a single wall in a room?! (pro 16) Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 30, 2015 Share Posted November 30, 2015 In a camera view you can click on the wall you want to edit, you left-click then hit the tab key or next button. When that is properly done you can then see the wall's wall poly line, that will have handles on its four sides that you can then grab to edit the wall (alter its height). A second method is to format the wall to be a solid railing wall where its height can then be altered by way of the Newels and Balusters tab, height input box. DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted November 30, 2015 Share Posted November 30, 2015 https://www.homedesignersoftware.com/support/article/KB-00317/creating-a-half-height-wall.html This Knowledge Base article has instructions on creating a partial height wall. 1 Link to comment Share on other sites More sharing options...
