rcspott Posted November 10, 2015 Share Posted November 10, 2015 Hi Trying to design a warehouse with 12 ft ceilings. Inside the warehouse I am trying to have 2 rooms that have 8' walls and ceilings. One of the walls to each room share an exterior wall. Want to be able to store things on top of those 2 walls. Not able to achieve this. Plan attached. HD Pro 2015 Hope this is clear. Thanks Untitled 2.plan Link to comment Share on other sites More sharing options...
solver Posted November 10, 2015 Share Posted November 10, 2015 This is a fairly common request/problem. The software design makes this more complicated than it should be. You can model this by adding a 2nd floor. Think of everything up to the 8' level as floor 1, and everything above as floor 2. Use a room divider to outline the rooms below, and make the rest of the 2nd floor open below. Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 10, 2015 Share Posted November 10, 2015 https://www.homedesignersoftware.com/support/article/KB-00210/using-open-below-rooms-to-define-an-opening-to-a-lower-floor.html Link to comment Share on other sites More sharing options...
