archiebear15 Posted October 28, 2015 Share Posted October 28, 2015 I am having trouble duplicating an odd corner cupboard. A corner cupboard has four sides and a door. I am trying to change the length of the four sides ( each one is different) and am having trouble can someone help me. Thanks.... Link to comment Share on other sites More sharing options...
archiebear15 Posted October 28, 2015 Author Share Posted October 28, 2015 Pro 2016. Pantry.pdf Link to comment Share on other sites More sharing options...
archiebear15 Posted October 28, 2015 Author Share Posted October 28, 2015 Thank you very much I will try this. Link to comment Share on other sites More sharing options...
Jo_Ann Posted October 28, 2015 Share Posted October 28, 2015 I wouldn't use partitions, because they make adding a door very tricky and inconvenient. Using a wall will allow you to add a door that you can open to see the shelving inside the pantry 'room'.Using a 'half-wall' allows you to set it's height. The program will allow you to set it's thickness to a minimum of 27mm, but I think that's good enough to provide some stability.Using a cad line (shown in red) set to the dimension you need, will assist you in placing the walls.Use a custom countertop and shape it for the shelves. Once correctly shaped, open the dbx and uncheck "set height from cabinet". With shelf selected, copy/paste/hold position for however many shelves that you need. In the 3d window, grab each shelf and drag it to the correct height position. Lastly, add another custom countertop and precisely shape it to fit the pantry 'room'. Open the dbx and uncheck "set height from cabinet". Once again in 3d, drag it up to the top of the room to become the 'ceiling' of the 'room'. Hope this helps Link to comment Share on other sites More sharing options...
LawB10 Posted October 28, 2015 Share Posted October 28, 2015 draw the pantry using interior walls, use the shelf tool and resize and lower the shelf (s) to your liking. Add the door and change to glass or go to the library click Architecural>doors and doorways>glass panel>french doors. Link to comment Share on other sites More sharing options...
