tjcoy747chief Posted September 26, 2015 Share Posted September 26, 2015 I am using Designer Pro 2016, and slowly going through the manual. I am not a designer but have done enough remodeling to be dangerous . I am trying to do a pretty accurate lay out for a summer home in Philippines and everything is build with concrete and center block / hollow block. Spent lots of time in area on floor levels but can't seem to find how to remove a portion of the floor or ceiling from 1st floor. I can create the 2nd story without any problems except I need to make area above living area an open atrium from area where bedrooms upstairs can look down from balcony. Anyway any suggestions are very much appreciated. Thanks Tim Tablas 1st real drawing 03.plan Link to comment Share on other sites More sharing options...
Keith_K Posted September 26, 2015 Share Posted September 26, 2015 I can't open your plan to see the structural arrangement you have as I only have HD Pro 2014 but have you tried outlining the area you wont open (on the second floor) with invisible walls and then in the room dialogue select "open below"? Conversely if there is a definite room arrangement under this area, even using invisible walls again, unchecking "roof above this room" and "ceiling above this room" should give the same result. I think. Link to comment Share on other sites More sharing options...
solver Posted September 26, 2015 Share Posted September 26, 2015 Set the space (room) on the second floor as Open Below. Search the programs Help system for more info on Open Below. Link to comment Share on other sites More sharing options...
tjcoy747chief Posted September 26, 2015 Author Share Posted September 26, 2015 Thanks to both of you for getting heading in the right direction, this will be my afternoon project and again thanks for taking the time to respond. Tim Link to comment Share on other sites More sharing options...
