chiefuserrick Posted August 24, 2015 Share Posted August 24, 2015 Is there an easy way to save just the terrain? I spent a lot of time on it with my current home design and suspect that it will be one of many that I do on this same terrain. Link to comment Share on other sites More sharing options...
43214321 Posted August 24, 2015 Share Posted August 24, 2015 I would save just the terrain as a template. Then you can use it on numerous projects by just re-naming it. Link to comment Share on other sites More sharing options...
solver Posted August 24, 2015 Share Posted August 24, 2015 Yep, copy it to a new plan and save. Link to comment Share on other sites More sharing options...
chiefuserrick Posted August 25, 2015 Author Share Posted August 25, 2015 Great suggestions, is the terrain a separate file or do I save the whole plan as a new name and delete the house wall by wall till I'm just left with the terrain? Link to comment Share on other sites More sharing options...
solver Posted August 25, 2015 Share Posted August 25, 2015 Select the terrain, copy, paste into a new plan. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 25, 2015 Share Posted August 25, 2015 if you have ALOT of stuff in the Terrain ...not just the Terrain Perimeter , use the Save As way , and in the renamed Plan, delete the house etc , which in Pro you can use the Edit>Delete Objects Dialog for.... Later you can use Edit>All Floors to paste a new home in this Plan Link to comment Share on other sites More sharing options...
chiefuserrick Posted August 26, 2015 Author Share Posted August 26, 2015 Thanks all, I understand now. Link to comment Share on other sites More sharing options...
