Barrelhouse Posted July 25, 2015 Share Posted July 25, 2015 Will we need to go through the deactivation process when we move to windows 10 on the same computer (not sure how MS is gonna do the upgrade). Just installed Home Designer Pro. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 25, 2015 Share Posted July 25, 2015 If you upgrade, you should have to do nothing at all, only if you do a "clean install" would you then have to reinstall Home Designer. I recently installed Windows 10 on my laptop, the transition was flawless (all my programs stayed in place). I did not like how my laptop ran with Windows 10 so I un-upgraded and everything is still fine. My laptop is 8 years old, and not strong enough to run Windows 10 well, if your machine is less than 8 years old (it currently runs Windows 7 or 8) it should run Windows 10 just fine. I do plan to upgrade my desktop that runs Windows 7 to 10 when it is available. DJP Link to comment Share on other sites More sharing options...
Barrelhouse Posted July 25, 2015 Author Share Posted July 25, 2015 Thanks for the info Link to comment Share on other sites More sharing options...
katalyst777 Posted July 28, 2015 Share Posted July 28, 2015 Are you using the current version? It doesn't look as though anything other than the 2016 programs will be supported under Windows 10, although older versions might work okay. Link to comment Share on other sites More sharing options...
