bob-rpm Posted June 14, 2015 Share Posted June 14, 2015 How do you get extra layers for the subfloor defaults (3/4" osb board and 11.25 fir 2x12's)? Only one layer shows up. Link to comment Share on other sites More sharing options...
bob-rpm Posted June 14, 2015 Author Share Posted June 14, 2015 I'm using pro 2015 Link to comment Share on other sites More sharing options...
solver Posted June 14, 2015 Share Posted June 14, 2015 Could you explain "Only one layer shows up." Link to comment Share on other sites More sharing options...
Kbird1 Posted June 14, 2015 Share Posted June 14, 2015 Edit: Nope Sorry wrong program. Defaults>Floor>Structure Tab>Floor>Floor Structure (at bottom) uncheck default (?) and click edit , then Insert and define the Material Link to comment Share on other sites More sharing options...
Kbird1 Posted June 15, 2015 Share Posted June 15, 2015 Could you explain "Only one layer shows up." good point .... maybe I miss read the OP , maybe Floor Surfaces is turned off in Display Options? M. Link to comment Share on other sites More sharing options...
solver Posted June 15, 2015 Share Posted June 15, 2015 How do I add a layer? Lets say I want 2 layers of ply over the joist. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 15, 2015 Share Posted June 15, 2015 I guess you are Asking me Eric ..... you can't Sorry , forgot I was in X7 not Pro 2016 , but even in X7 you have to add it to the Floor Finish not the Floor structure layer if say you want two layers of Ply in a Bathroom area. If the Whole floor is 2 layers you can go with the Structure Layer. I will alter the above Post Link to comment Share on other sites More sharing options...
bob-rpm Posted June 15, 2015 Author Share Posted June 15, 2015 Eric, In your above attachment I'm only getting layer I, not the two in your pic. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 15, 2015 Share Posted June 15, 2015 post a pic of your DBX , I haven't seen Pro with only one uneditable layer , you have Pro 2015 right? what Eric shows is the standard OOB DBX settings.. M. Link to comment Share on other sites More sharing options...
bob-rpm Posted June 16, 2015 Author Share Posted June 16, 2015 Mick, The file/export isn't available when I'm in the floor structure definition window. Yes I'm using pro 2015. The odd thing is in a previous plan the two layer option showed up, but in this new plan I'm only getting one layer. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 16, 2015 Share Posted June 16, 2015 Eric and I are using the Windows Snipit Tool in Accessories to take pics of DBX's . Are you using a different template plan if okay before ? Link to comment Share on other sites More sharing options...
bob-rpm Posted June 16, 2015 Author Share Posted June 16, 2015 Mick,Thanks for showing me that tool. The image is enclosed. The template is the same as before, more exactly the new plan is built on the topography of first, Everything deleted and built again. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 16, 2015 Share Posted June 16, 2015 I don't see anything obvious Bob perhaps post the plan so someone else can look at it . you might want to ask TS too . It's not a template plan brought forward from a lessor version of HD software is it? they cant alter floor structures.... Link to comment Share on other sites More sharing options...
