Auto interior and exterior dimensions
RHammer
David's method only turns off the display of existing dimensions.  It doesn't delete them or stop them from updating.
Instead . . .
Edit> Default Settings> Dimension> Auto Exterior Dimension Defaults
Uncheck Auto Refresh Dimensions
Click OK
Then, Edit> Delete Objects> All Floors> check Automatic Dimensions then click the Delete button and Done to actually get rid of them.
Or just select one of the auto dimensions and click on Delete.  It will prompt you asking if you want to turn off the Auto feature and you can choose Yes and only get rid of the dimensions you want.
  • Upvote 2
