A1Renovations Posted July 2, 2025 Share Posted July 2, 2025 Might be a really simple answer. How would you create an exterior wall with 2 different finishes in Home Designer Architectural 2025. I am trying to give the exterior walls on a build a rendered colour for the top two thirds of the wall and the bottom 500mm of the wall in a stone cladding like brick slip principle. Please see attached image that is exactly what I would need the outside walls to look like. I have the rendered top part no issues its just adding the stone detail to the bottom that seems to be complicated Link to comment Share on other sites More sharing options...
Rookie65 Posted July 2, 2025 Share Posted July 2, 2025 If architectural doesn't have pony walls, then use an exterior wall covering. You can read about them in your reference manual Link to comment Share on other sites More sharing options...
y-g-m-n Posted July 3, 2025 Share Posted July 3, 2025 The term for your type of wall is called PONY WALL as stated above. Bottom portion one type of finish and the top is another finish. Can be interior walls too. I know PRO has this. Link to comment Share on other sites More sharing options...
