Whereditgo Posted July 1, 2025 Share Posted July 1, 2025 For this example created a New Plan (Default Style). Home Designer Pro 2025. Build Wall (Exterior), checked Layer Display Options "Framing, Wall" to show wall studs. Selected a single wall stud object and Copy "Ctrl+C" Then paste "Ctrl-V". Question Window Displayed: Selected "Yes" to turn off Automatic Wall Framing." Warning Window Displayed: Wall stud/framing objects can be edited/moved but unable to add/paste. In the 3D Perspective Framing View, I am able to modify/move framing. Again get same Warning when trying to copy/paste a new framing object (stud). Warning Message Appreciate any assistance/guidance to resolve. Thanks Similar thread/question asked here, but does not seem to resolve.... Link to comment Share on other sites More sharing options...
Rookie65 Posted July 1, 2025 Share Posted July 1, 2025 Maybe try adding a stud using the "post" item in the general framing tab? Set it at the stud size and height and see if that works. As a post, it should also show up in your framing view, as long as "posts" are turned on to display Link to comment Share on other sites More sharing options...
Whereditgo Posted July 1, 2025 Author Share Posted July 1, 2025 Appreciate the suggestion/workaround. Actually tried that earlier and was able to add the post to the wall. Just curious if the Copy/Paste is User Error (not knowing how its done), Home Designer Pro limitation (have seen this come up/limited CA feature) or slim chance a bug. Thank You Link to comment Share on other sites More sharing options...
y-g-m-n Posted July 2, 2025 Share Posted July 2, 2025 why mess with framing as it is kinda generic... framing crews may start studs at other end or whatever I can pretty much say the one thing they do not do is look at framing plans for where each stud should go. They will look at Framing details for what the plans state for ceiling height, beams sizes, joist sizes, headers, corners and mainly roof framing details like knee walls, collar ties, etc. But to waste any time on locating studs; something behind the sheet rock and never seen and that pretty much has no bearing on home plans seems a waste of time to me... Link to comment Share on other sites More sharing options...
Whereditgo Posted July 2, 2025 Author Share Posted July 2, 2025 Agree, the specialized crew/contractor will adapt (framers/plumbers/electricians...). In this case the actual wall design is not one typical framers deal with. My current design is based on “Joseph Lstiburek’ perfect wall: https://buildingscience.com/documents/insights/bsi-001-the-perfect-wall Basic wall is 2x4 16" O.C. frame with a DIY SiP panel (ZIP, 4" Poly ISO, ZIP) attached with long SIP/Insulation screws to the studs. In this case I need double/backer stud positioned 4 feet O.C. (to accept long SIP/Insulation Screws at vertical ZIP panel joints). Again,Just curious if the Copy/Paste is User Error (not knowing how its done), Home Designer Pro limitation (have seen this come up/limited CA feature) or slim chance a bug. Thanks Link to comment Share on other sites More sharing options...
Solution ChiefTylerL Posted July 2, 2025 Solution Share Posted July 2, 2025 @Whereditgo Wall framing can only live inside of the wall, and when you copy+click to paste, it isn't trying to paste it into the wall object, meaning you're met with that message. Instead to copy/paste wall framing, in any view, you're going to select the stud, click Copy, and then use the Move edit handle to move a copy of the stud. I have created a short gif that demonstrates this process in a cross section view, but this can be used in camera view or in plan view. If you're curious on how to create a cross section framing view, please see this Knowledge Base article: https://www.homedesignersoftware.com/support/article/KB-01188/creating-an-elevation-view-of-wall-framing-in-home-designer-pro.html I hope this helps! Link to comment Share on other sites More sharing options...
Whereditgo Posted July 4, 2025 Author Share Posted July 4, 2025 That worked perfectly! Thank You Very Much! 1 Link to comment Share on other sites More sharing options...
