Chief Download Library
y-g-m-n
I have some issues with your false advertising which I think you can easily fix.
EXAMPLE
FEATURED catalog for BLUMSAFE - what a great idea let me down load and check it out.
Says compatible with HD PRO so I cam good to go.
WRONG..
Does not work as for CA latest only.
Can you either put in proper download file for HD products or correct where you says it works with HD..
Have others like that too.
BonusMEPToggleSwitches yeah more switches - WRONG unless you have CA.
Hello and thank you for your feedback.  The Blumsafe catalog was released after the release of our newest version (Chief Architect X17).  When we release the Home Designer equivalent of X17 (Home Designer 2026), you will then see availability for Home Designer.  Catalogs that are released are available for the current version and future versions.  They are not backward compatible.
I will pass your feedback on to our catalog team to see if we can fix the issue you have discovered.
Kind regards,
Derek
Chief Architect Software
  • 10 months later...
catalogs used to be available to several versions of the home designer series.  For example a catalog for 2025 also had downloads for 2024 or 2023 etc.  No longer is this happening.  All the catalogs are now just available for the subscription versions and all the previous versions are cut out.  I find this very wrong for all the customers who have supported your software and are now pretty much forgotten.  Why can't catalogs still be available to previous versions as they had always been in the past.
Because, as you said, they seem to be purposefully ignoring 2025 and earlier customers in order to gather more rental customers. And if they happen to answer you with something about compatibility issues, I would argue that is BS.
  • 2 weeks later...
Yeah I have 2025.  Imagine paying for multiple versions, and then within less than 18 months you are 'legacy'. I'm not buying for one second that there are compatibility issues that cannot be resolved in catalog items like the upscale appliances for example.  Very disappointed and feeling trapped.  This product has a steep learning curve. I finally get to a point where I can limp along and now I'm hamstrung. I am furious. The subscription price is out of line.  Time to learn Sketchup I guess.
Exactly.  I'm a hobbyist and only use the program on personal projects and for friends.  The legacy version that I purchased in 2021was working just fine for me.  Then my computer crashed and I bought a new one.  When I re-installed my legacy HomeDesignerPro, I lost probably 50% of the libraries I had purchased and all of the manufacturers catalogs...Kohler, Benjamin Moore, etc.  There's no way I'm upgrading to a rental model for a hobby.  And like bumblebeelyfe, I had committed a lot of time to mastering this program.  WHAT A WASTE.  Way to screw your customers!  Reluctantly looking for new options now.
