KilgoreRemod Posted June 14, 2025 Share Posted June 14, 2025 I have a fully designed house that I am about to start construction on. I need to create a foundation plan, but the drawing will only show part of the footers when i go to floor 0, and i cannot create dimension lines or a detailed drawing for the concrete crew off of what shows up. I can see the foundation and footing clearly in 3d perspective full overview, but they do not exist on floor 0 view. I cannot attach the plan to this question because the file size is too large. I can attach screen shots of the issue. Aaron Kilgore Kornerstone Building Solutions Windows 11 HD Pro 2024 Link to comment Share on other sites More sharing options...
y-g-m-n Posted June 15, 2025 Share Posted June 15, 2025 how did you build foundation? Should use the BUILD FOUNDATION button. Link to comment Share on other sites More sharing options...
KilgoreRemod Posted June 15, 2025 Author Share Posted June 15, 2025 I drew in my exterior walls and the foundation was automatically generated from that. Link to comment Share on other sites More sharing options...
KilgoreRemod Posted June 15, 2025 Author Share Posted June 15, 2025 for the exterior patios, I drew in handrails at the edges and modified them to be post to beam with no railings, patio slabs were auto generated from that. Link to comment Share on other sites More sharing options...
y-g-m-n Posted June 16, 2025 Share Posted June 16, 2025 I would turn off auto foundation and run BUILD FOUNDATION in plan view while on first floor. Then go down to 0 floor and see what happened. MAke sure you have FOUNDATION layer and maybe footings turned on in LAYER DISPLAY OPTION Link to comment Share on other sites More sharing options...
