Beam not showing above stairs
Turnall
Go to solution Solved by Garybills,
2 hours ago, y-g-m-n said:
how did you make beam?
what type of element is it?
Ceiling beam or a soffit or a 3d object or ??
It is soffit. I have 2 of them in the living area. The other beam is fine so I assume its the stairs causing the issue (not sure if I'm correct).Not sure about what type "element" it is.
BTW, this is Home Designer Pro '22.
Thanks.
Allen
11 hours ago, Garybills said:
If you built the soffit on the first floor, try building it on the second floor.
Thanks @Garybills!!
Very simple to do. I copied the beam, then went to the 2nd floor and hit Edit/Paste/Paste Hold Position. I then had to change the height from the floor (2nd floor). In case anyone else needs to know.
Thanks again Gary!
Allen
