Turnall Posted April 26 Share Posted April 26 How do I make the beam display above the stairs? Probably simple, but I can't seem to get it. Thanks in Advance... Allen Link to comment Share on other sites More sharing options...
y-g-m-n Posted April 26 Share Posted April 26 how did you make beam? what type of element is it? Ceiling beam or a soffit or a 3d object or ?? Link to comment Share on other sites More sharing options...
Turnall Posted April 26 Author Share Posted April 26 2 hours ago, y-g-m-n said: how did you make beam? what type of element is it? Ceiling beam or a soffit or a 3d object or ?? It is soffit. I have 2 of them in the living area. The other beam is fine so I assume its the stairs causing the issue (not sure if I'm correct).Not sure about what type "element" it is. BTW, this is Home Designer Pro '22. Thanks. Allen Link to comment Share on other sites More sharing options...
Turnall Posted April 26 Author Share Posted April 26 The house is coming along just fine, but I would like to fix the issue in HD. Allen Link to comment Share on other sites More sharing options...
Solution Garybills Posted April 26 Solution Share Posted April 26 If you built the soffit on the first floor, try building it on the second floor. Link to comment Share on other sites More sharing options...
Turnall Posted April 27 Author Share Posted April 27 11 hours ago, Garybills said: If you built the soffit on the first floor, try building it on the second floor. Thanks @Garybills!! Very simple to do. I copied the beam, then went to the 2nd floor and hit Edit/Paste/Paste Hold Position. I then had to change the height from the floor (2nd floor). In case anyone else needs to know. Thanks again Gary! Allen Link to comment Share on other sites More sharing options...
y-g-m-n Posted April 27 Share Posted April 27 try ceiling beams next time. Insert one then select and open edit window and hit HELP. tons of info and more suited to what you are doing. 1 Link to comment Share on other sites More sharing options...
